Stock code:SZ 002334
Current location:Home Solutions Building Materials
Building Materials
Building Materials
Building Materials
INVT provides equipment electrification, integrated process control, optimization solutions, motors and drive systems and other series products
More>>
  • INVT VFDs Applied to Fans in the Cement Plant
    INVT VFDs Applied to Fans in the Cement Plant. There are many kinds of fans in the cement plant. For example, Raw- material mill ID fan/ Coal mill ID fan/ Cement mill ID fan/ Preheater high-temperature fan/ Kiln end fan / Kiln head fan/ the grate cooler/ separated fan and transport power fan. These fans consume a lot of energy.
  • INVT VFDs Applied to Pumps in the Cement Factory
    Due to transport cooling water/ wastewater and mortar, there are some pumps in the cement factories. With today's VFD technology those pumps can be controlled with the best possible efficiency without compromising reliability. Furthermore, mechanical maintenance costs can be reduced by controlling the water flow with VFDs instead of throttling valves or hydraulic couplings.
  • INVT VFDs Applied to Rotary Kiln in the Cement Plant
    Rotary kiln is a very important device in the cement plant. Variable speed drives are used to control the rotational speed of cement kilns. As the speed of material flow through the kiln is proportional to rotation speed, a VFD is required to control it. In addition to speed, VFDs provide controlled torque.
  • INVT VFDs Applied to Conveyors in the Cement Plant
    Conveyors are found in almost every cement plant. As shown in the picture, conveyor load is transporting raw-material / coal and cement. The environment is demanding and there is always a risk of damaging the belt by overstretching, slipping or breaking. So conveyors driven by VFDs can bring in below benefits.
  •  INVT VFDs applied to VRM (Vertical roller mill) and ball mill
    The effect of mill is used mechanical power to change big size of the material to small size in order to meet with cement plant requirement. For the big capacity cement plant, the mill rated power is very huge, maybe more than 5000kw. How to smoothly start without impact current and voltage, and how to adjust mill speed, are obstructing cement plant. Control them with VFDs results in the following benefits.
  • INVT VFD Products Applicated in the Cement Industry
    INVT VFD Products Applicated in the Cement Industry, include GD5000 series vfd, GD800 series vfd, GD300 series vfd and GD200A series vfd.
  • INVT Medium voltage/Low voltage VFD Support Cement Industry
    With the development of VFD (Variable Frequency Drive) technology, more and more VFDs are used in the cement industry to meet different needs. INVT took more than 10 years to design and generalize VFDs for cement industry.
  • India Cement Project - INVT GD5000 MV VFD
    INVT worked with this company since 2010; there are more than 40 sets of INVT medium voltage VFD drives are being used in different applications. Exhaust fan Fans, ID fans, Boiler Pumps, VRM, ball mills etc.
目前在第1页, 共有2页, 共有14条记录 第一页 上一页 12 下一页 最后一页 跳转到
Email: overseas@invt.com.cn
Online top
