Solar Grid-tie Inverter Project Case On The Sea
Release time:2020-08-27
Click amount: 4305
Introduce: Solar Grid-tie inverter(PV inverter or solar inverter) can convert the variable DC voltage generated by photovoltaic (PV) solar panel into the inverter with the mains frequency AC, which can be feed back to the commercial transmission system, or used for the off grid grid power grid. Photovoltaic inverter is one of the important system balance (BOS) in photovoltaic array system, which can be used with general AC power supply equipment. The solar inverter has special functions to cooperate with the photovoltaic array, such as maximum power point tracking(MPPT) and island effect protection.
1.Product circuit diagram and specification
Below show the product of the projuct case on the sea.
Specification:
2.Project case:
Project 1:The installation of 3.2MW on grid solar power system
Date: 2018-08-03
System Capacity: 3200KW
Inverter: INVT IMars BG series 50KW (64pcs)
Pictures of the customer site are shown below:
Project 2: The installation of 96KW on grid solar power system
Date: 2015-11-16
System Capacity: 100KW
Inverter: INVT IMars BG series 50KW (2pcs)
3.Customer Reviews:
INVT IMars BG series can use on the sea,stable operation in high salt fog and high humidity environment. Product reliability fully meets customer needs.
4.Ending:
Through the above projects, it is proved that IMars series solar inverter can work stable in harsh environment. It fully embodies the excellent performance of IMars series solar inverter.
Reference
[1] 《Operation Manual Photovoltaic Grid-connected Inverter》Shenzhen INVT Electric Co., Ltd.
