Application of Cardless Rotary Cutting Machine
Release time:2021-02-23
Click amount: 2128
Introduce: The cardless rotary cutting machine is to put a certain length of round wood into the machine table, and the rollers on both sides of the front and rear are rotated, and the rotary cutting is achieved by the method of extrusion and rotation. The diameter of the processed log can be as small as 1cm. Line speed can reach 150m/min. High accuracy, thickness error within plus or minus 1mm, width error is plus or minus 2mm, it is a high-efficiency and high-precision rotary cutting equipment. This machine uses GD200A, the control system uses IVC1L PLC to control the whole system.
Keywords: cardless rotary cutting machine,GD200A,IVC1L
1.Process requirements
(1)Accurate calculation of wood core radius
(2)The cutter responds quickly to ensure the cutting accuracy
(3)The feed inverter responds quickly to ensure the even thickness of the veneer
(4)Adjustable speed in operation
(5)Unattended, automatic operation
2.Configuration and solution
The cardless rotary cutting machine uses INVT PLC: IVC1L and HMI: VS070.
RS485 communication is adopted between PLC and HMI. PLC has three 50K pulses. One is for speed control of single and double roll. One is for speed control of feed VFD. The cuting VFD communicates with PLC through RS485, changing the length of the cutting.
NameModelQty.
PLCIVC1L1
HMIVS0701
Single and double roller VFDGD200A-030G/037P-41
Rubber roller VFDGD200A-015G/018P-41
Feed VFDGD200A-2R2G-41
CutterGD35-2R2G-4-H11
3.Electrical diagram
4.Control process
The cardless rotary cutting machine is consists of machine base, double roller system, single roller system, tool post, transmission system and electrical system. Mainly for the round wood processing, a certain length and diameter of the round wood for rotary cutting, after cutting into a certain specification of veneer, cut out veneer must be complete and have strict length and thickness requirements.
Single and double roller: The single roll and double roll clamp the round wood, and the rotation drives the wood to rotate.
Feed VFD: After the wood is rotated, the feed motor runs according to the calculation curve to make the wood cut evenly.
Rubber roller variable frequency drive: Transport veneer.
Cutter: The cutting knife cuts a piece of veneer every turn, the length of veneer can be modified on the HMI.
5.VFD parameter setting
Cutter VFD
P00.00Speed control mode3
P00.01Run command channel1
P00.03Max output frequency200
P00.04Upper limit of the running frequency200
P00.11ACC time0.5
P00.12DEC time0.3
P05.01S1 terminal function1
P05.02S2 terminal function45
P05.04S4 terminal function7
P05.06S6 terminal function4
P08.06Jogging frequency50
P08.07Jogging ACC time0.6
P08.08Jogging DEC time0.6
P14.00Local communication address5
P14.02Communication baud ratio0
P20.00Encoder type0
P20.01Pulse number2500
P21.28ACC/DEC time after pulse prohibition40
P23.00
P23.03
220
P23.04
150
P23.05
10
P23.06
120
P23.07
600
P23.11
14.6
P23.16
3
P00.00Speed control mode2
P00.06A frequency command selection4
P00.11ACC time0.5
P00.12DEC time0.8
Rubber roller VFD
P00.11ACC time0.5
P00.12DEC time0.8
Feed VFD
P00.11ACC time0.5
P00.12DEC time0.8
P05.02S2 terminal function2
P08.37Breaking enable1
6.Ending
The cardless rotary cutting machine was developed by INVT. VFD, PLC and HMI are all products of INVT, which reflects that INVT has a richer product line and has system integration capabilities, which can provide OEM customers with a complete set of system solutions.
Reference
[1]《GD200A Series VFD Operation Manual V2.4》Shenzhen INVT Electric Co., Ltd.
[2]《GD35 Series VFD Operation Manual V3.5》Shenzhen INVT Electric Co., Ltd.
