INVT Solution for Chain link machine in India
Release time:2023-09-15
Click amount: 507
Abstract:
A common material used for enclosing areas like backyards, sport fields, playgrounds and industrial areas, chain link fencing is a very versatile and affordable option for residential and commercial customers. Also known as hurricane or cyclone fencing, due to its durability and ability to withstand gale force winds, chain link fencing is a type of fence that is made of woven, inter-locking steel wire. The stability comes from steel posts that are cemented into the earth before attaching the affordable fencing material.
Keywords: IVC1L, DA200, POSITION CONTROL, VS HMI, MODBUS COMMUNICATION
I.Introduction
When user press start button then servo rotate as per set length with a rpm set in HMI, As soon as servo complete the operation then shear/cutter motor start rotating to cut the pulled wire and stop in home sensor, After that bed/table motor starts rotating to link the metal wire and stop at sensor becomes high, after that twister motor rotated and stop as the sensor input is high after that un winder motor starts and stop as un winder sensor is high. This process is continuing till the number of cycle that is pre set in HMI. All on delay and off delay timers are set in HMI.
II.Project information and Solution
1. Project information
Site information: Steel/Metal Line
2. INVT solution
ProductModel no.QtyApplication
PLCIVC1L-2416MDT1CONTROLLER
HMIVS070HE-1
HMI
SERVO   DRIVESV-DA200-5R5-4-S01MATERIAL FEED
SERVO   MOTORSV-MM18-5R5B-4-1A0-10001MATERIAL FEED
System Configuration:
III.System commissioning
Control panels
IV.Advantages and benefits
a)1) Long-Lasting Durability
b)Easy Repair
c)Easy Maintenance
d)Design Options
e)Security, Safety and no Human error
V.Conclusion
Chain link fencing is much easier to install than many other types of fencing material. Because of this, it will cost less to have it installed than brick, wood, PVC or other types of fencing. The initial purchase cost of chain link fencing is also one of the most affordable fencing materials available, INVT provides economical and high performance solutions against Mitsubishi/Delta. We replace both brand PLC,HMI and servo and Proven this machine.
