Application of INVT GD380L special inverter for elevator
Release time:2022-11-11
Click amount: 1399
Abstract: GD380L is special elevator drive developed for all type of elevator like home lifts, passenger and goods lifts etc. This paper gives the detailed solution installation and commissioning details for GD380L. Engineering practices, market survey and feedback shows that GD380L has good control performance and stability.
Keywords: INVT GD380L, Geared Machine.
I.Introduction
GOODRIVE380L series inverters are the new-generation elevator inverters developed on the new INVT control platform. Goodrive380L series inverter improved great achievements in security and reliability, control performance and use functions Basic performance.
Basic performance:
1.Ability to drive asynchronous (Geared )and synchronous (Gearless) motors
2.Support open loop control mode without encoder and closed loop control mode with encoder.
3.Static & rotational motor tuning for the initial pole angle of PM motor
4.Support multiple type of encoder: incremental, sine-cosine, absolute encoders and built in incremental PG card
5.ACC/DEC S-Curve Algorithm: Improve comfort during ACC, DEC and stop.
6.Starting weight compensation with and without weight sensor to prevent reverse slip at startup, ensuring stable lift startup.
7.Emergency-rescue mode & search the direction in light load.
Special functions
8.In-Built LCD keypad interface.
9.In-Built Incremental PG card.
II.Configuration of GD380L elevator
Installation of GD380L on lift has below detail:
Tab 1 Lift information
Lift speed
1.0 m/s
Capacity
6 persons, 408KG
Floor
5 floors
Power supply
3phase 415V
Motor type
Asynchronous motor
Rated power of motor
3.7 kW
Fig INVT GD380L Control Panel and motor with nameplate
1.GD380L electrical configuration
According to the lift configuration and the demanding functions, we provide the electrical solution as follow. Considering higher ambient temperature, one grade higher of machine rating is selected.
Tab 2 Configuration list
Item
Model
Qty
GD380L Inverter
GD380L-5R5G-4
Geared Motor
TECHNIK S60
Brake resistor
65Ω/1500W
Fig GD380L Inverter
2.GD380L parameter setting
Basic parameters setting are as follow.
Function Code
Description
Setting Value
P00.00
Speed control mode
Sensorless vector control mode 1
P00.01
 Channel of running commands
                  1: Terminal
P00.02
Rated speed of elevator
0.100~4.000m/s
1.000
P00.03
Speed command selection
     3: Multi-step speed running
3
P02.00
Motor type selection
0: Asynchronous motor
P02.01
Rated power of the motor
0.1~3000.0kW
3.7
P02.02
Rated frequency of the motor
0.01~P00.04
50
P02.03
Rated speed of the motor
1~36000rpm
1440
P02.04
Rated voltage of the motor
0~1200V
400
P02.05
Rated current of the motor
0.8~6000.0A
9.0
P03.00
Proportional gain of speed loop
0~100.0
25
P03.03
0~100.0
25
P05.01
S1 terminal function selection
1: Upward running(FWD)
P05.02
S2 terminal function selection
2: Downward running(REV)
P05.03
S3 terminal function selection
8: Multi-step speed 1(MS1)
            8
P05.04
S4 terminal function selection
9: Multi-step speed 2(MS2)
            9
P05.07
S7 terminal function selection
4: Emergency running(EMER)
            4
P06.03
Relay RO1 output selection
7: Brake control
7
P06.04
Relay RO2 output selection
8: Contactor control
8
P09:00
Multi-speed 0
0.000~P00.02
0.200
P09:01
Multi-speed 1
0.000~P00.02
0.700
P09:02
Multi-speed 2
0.000~P00.02
0.075
III.Conclusion
After installation of GD380L, the elevator runs perfectly. The customer is very satisfied. And GD380L can support to open loop, closed loop for Geared & Gearless machine, have LCD display for convenient debugging.
