INVT combo HMI&PLC for booster pump in commercial building in India
Release time:2022-02-11
Click amount: 2021
1. Introduction
Booster pump is a pump used for pressurization. Its main applications include water heater, high-rise building with low water pressure, sauna, bath and other pressurization, solar automatic pressurization, reverse osmosis water purifier pressurization and so on. Booster pump provides a variety of optional features like:  thermal overload protection, rated run continuously and multi information display, etc. Sensors, HMI and PLC with digital input / output, analog input and outputs are installed to achieve these functions. The system diagrams are as below:
Booster pump system components
Booster pump system control diagram
Site device photo
There is a commercial building need booster pump to increase the water pressure and flow. Total five pumps are there, need to control by PID to maintain the pressure. In order to saving cost and save the installation space, INVT control solution is as below:
Product
Model no.
Qty
Application
Integrated PLC/HMI
VS-0701614MDR1
Controller
System configuration
The control diagram is as below:
3. System commissioning
According to the control logic and display requirement, PLC and HMI program are made and uploaded to VS-070-1614MDR.
The HMI pages and control panel photos are as below:
HMI pages
Control panel photos
4. Advantages and benefits
After commissioning, the system runs steady; the water pressure is maintained well with high accuracy. The advantages and benefits are as below.
* Combo HMI and PLC, cost effective.
* Compact size, saving installation space
* PID control maintains the pressure steady.
* Friendly user interface, easy to operate
* Cascade of pumps, high Efficiency.
5. Conclusion
Normally for this system needs HMI and PLC separately, but INVT provides an integrated PLC/HMI which have 2 analog input, one analog output, Modbus port inbuilt to fulfill this requirement of booster pump application which is very economical, compact and the pressure control resolution up to 0.1 bar. Customer is very satisfied with this solution.
