GD5000 MVD Solution for Cement Vertical Roller Mill in India
Release time:2021-04-02
Click amount: 2227
1.Project introduction
Vertical roller mill machines are very important in the cement plant. Along with development of variable frequency drive controlling technology, nowadays mostly asynchronous motors are driven by variable frequency driver instead of old traditional technology such as soft starter to realize automatic control and changing cement production.
Customer has below serious challenges:
1.Can’t increase cement product.
2.Grid line power factor is low.
3.High fault ratio and high maintenance costs for Slip-ring motor.
Site cement mill:
Table 1.Cement mill Motor Parameters
Motor ModelPowerRated VoltageRated CurrentRated SpeedPower FactorLoad Type
MAW 800L8000KW11000V483.4A994RPM0.89The cement Vertical mill
Figure 2.The cement mill motor
2.System Configuration
Based on INVT experience on vertical roller mill variable frequency drive renovation project, INVT can supply whole solution for the customer.
INVT suggest VFD solution:
Table 2.MVD for Cement mill
VFD ModelPowerRated VoltageRated CurrentOther
GD5000-A12500-11-D10000kw11KV656A/
Figure 3.The cement mill VFD
3.Features and Advantage
After using MV Drive, there are some major advantages as follow,
1.Increase cement product.
Table 3.Increase cement product
Before using MVDAfter using MVDRemark
Motor running speed994RPM1094RPMChange Slip-ring motor to squirrel-cage motor
Cement product capacity(PSC)240TPH336TPH
Increase cement product ratio(336-240)/240=40%
Figure 4.VFD running at 55Hz and 1094RPM
2.Increase grid line power factor.
The grid line power factor is over 0.97. So don’t need capacitor compensation device.
3.Very low torque pulse.
Low torque pulse without causing the resonance between the motor and other mechanical devices, and reducing the transmission mechanism wearing.
4.Perfect output waveform.
5.Prolong motor working life time.
6.Reduce maintenance costs.
4.Conclusion
Compared with original vertical roller driven method, the MVD driven method has many advantages. Especially increase cement product. The MVD system is easily controlled by CCR and the MVD running speed can automatic adjusted from 0RPM to 1094RPM. The upgraded MVD system works very well, customers are satisfied with INVT solution and INVT MVD met with customer’s requirements.
