INVT Exhibited at The 134th Canton Fair with “Green Technology”
Release time:2023-10-26 Click amount: 3072
From September 15th to 19th, 2023, INVT participated in the 134th Canton Fair". Despite the advanced technology in today's world, there are still many regions globally facing issues such as drought, desertification, and water scarcity, which directly impact the daily lives of local residents and pose significant threats to industries like agriculture and manufacturing. INVT, with its innovative thinking, has launched a series of advanced solutions and products for agricultural irrigation, desert greening, and domestic water usage, using the power of technology to improve people's lives.
Solutions
Exploring the Future of Renewable Energy Desertification Solution - In harsh desert environments, vegetation irrigation equipment requires high standards. INVT's GD100-PV Series Solar Water Pump VFD can be paired with drip irrigation, seepage irrigation, and sprinkler irrigation equipment, achieving water-saving, energy-saving, and efficient irrigation.
Desert Management Solutions
Desert areas themselves have little water, so they have higher requirements for vegetation irrigation efficiency. In addition, unfavorable factors such as sandstorms and temperature differences in desert areas also affect the stability of the equipment. GD100-PV series Solar Water Pump VFD supports photovoltaic input and complementary input from diesel generators or power grids to achieve efficient irrigation.
1. Support mixed input, AC+PV power supply, priority use of solar energy, intelligent AC power complementation
2. Long distance output, supports 200 meters without reactor
3. Adopting IP54 cabinet design for outdoor installation, anti-theft and adaptable to harsh environments
4. Intelligent Internet of Things can realize remote control of equipment, status monitoring, fault and early warning reminders through mobile phones
Domestic water solutions
In many areas, the cost of water is too high due to insufficient power infrastructure, high electricity prices or inability to cover the water pipe network. INVT SPC solar water pump controller provides domestic water scenarios with small flow and low head requirements. Low cost and effective solution.
Features:
1. Simple installation, using water storage device instead of electricity storage to meet 24-hour water demand:
2. The system cost is low, and solar energy is used as the system energy source;
3. IP66 protection level is high and can be installed directly outdoors to prevent theft;
4. Supports single-phase water pumps, brushless DC water pumps, and three-phase AC water pumps (synchronous, asynchronous).
Swimming Pool Solutions
Filling, replenishing, replacing and circulating water in swimming pools consumes a lot of energy, resulting in high water bills. INVT's BPD series solar water pump water supply solutions effectively utilize solar energy, reduce carbon emissions, and achieve better economic benefits and environmental protection.
Features:
1. IP65 high protection level, can be installed directly outdoors;
2. Fanless design, low operating noise;
3. Standard boost module supports low DC voltage input;
4. Io T function: Supports mobile phone control of device start and stop.
Agriculture Irrigation Solution
The solar water pump system is used to extract groundwater to irrigate crops, which reduces water pumping costs and has significant economic benefits. INVT GD100-PV Series Solar Water Pump VFD can be used with drip irrigation, infiltration irrigation, and sprinkler irrigation equipment to achieve water-saving, energy-saving, and efficient irrigation.
Features:
1.Support mixed input, AC+PV power supply, priority use of solar energy, intelligent AC power complementation
2.Long distance output, supports 200 meters without reactor
3.Automatic operation around the clock, unattended
4.Optional IP54 solution, directly used for outdoor installation and anti-theft
GD27&Solar Pump System
Products
INVT also unveiled new products at the exhibition, supporting the development of new energy. These products include grid-tied inverters, energy storage inverters and systems, and off-grid inverters, demonstrating the advantages of their solutions for residential grid-tied, off-grid, and solar energy storage scenarios.
XG1-5KW-S single phase on-grid solar inverter
The XG1-5KW-S is a single-phase grid-tied inverter developed for residential users. It supports a maximum of 20A current for a single string, 1.5 times DC over-sizing, and is compatible with high-current modules. It features multiple intelligent protection functions, compact size, lightweight, easy installation, and maintenance. With its intelligent management system, it enables centralized monitoring, remote diagnostics, and real-time maintenance.
XD3-6kW single phase hybrid solar inverter
The XD3-6kW single phase hybrid solar inverter adopts a home appliance design, with an exquisite and stylish appearance that blends harmoniously with residential settings. It is waterproof and dustproof, compact, lightweight, and easy to install, suitable for various installation scenarios. It supports solar, batteries, household appliances, and grid connection simultaneously. It offers multiple application modes such as self-consumption, peak shaving, battery priority, and backup power. It also supports parallel connection of multiple units, making it suitable for various home energy storage applications.
XD3-6kW-AIO all in one energy storage system
TheXD3-6kW-AIO all in one energy storage system integrates the inverter and energy storage battery into one unit. It has an exquisite appearance, compact size, and lightweight design. It supports multiple application modes and is suitable for various home energy storage environments.
XN3-5.5kW single phase off-grid solar inverter
The XN3-5.5kW single phase off-grid solar inverter combines traditional offline uninterruptible power supply technology with solar power control. It supports multiple charging voltage levels and can adapt to various batteries. With integrated multiple protection functions and an intelligent management system, it provides flexible, reliable, and continuous power supply solutions for areas not covered by the grid.
During the five-day exhibition, INVT utilized the international and professional platform of the Canton Fair to showcase its excellent products, rich industry experience, professional solutions, and on-site demonstrations on how to address and solve water scarcity issues.
INVT's participation in the exhibition showcased its commitment to supporting the development of new energy and providing comprehensive solutions for different scenarios. By addressing water scarcity challenges through innovative technologies, INVT is contributing to a sustainable future for both humans and nature."
Next Stop: 2023 Nuremberg Industrial Automation Exhibition in Germany INVT will bring you more exciting innovations. Stay tuned!
