INVT Solar Pumping Solution for Lebanon Water Supply
Release time:2024-05-14
Click amount: 1002
Project Background:
With the vigorous development of the global photovoltaic clean energy market, INVT's Solar water pumping system has gradually replaced traditional diesel generator water pumping systems, becoming the main water supply system in areas and countries with a lack of electricity. Leveraging the power of INVT, we provide a new, optimized, and economical solution for the water supply needs of areas in the Middle East with poor or no electricity, lighting up the lives of people in the Middle East.
Customer Requirements:
In areas with poor or no electricity, it is generally required that
1. System design: The system should meet the daily agricultural water supply and livestock water supply needs of mountain farms, support AC/Solar input, run continuously day and night, and also support the water level control of wells and water storage tanks.
2. Maintenance: Since there are only farmers on-site, the system usage needs to be as simplified as possible, preferably achieving unmanned operation and a remote monitoring effect.
3. Cost: Considering the local economic conditions, it is necessary to reduce the overall system construction cost and later overall usage cost.
INVT Solution:
Therefore, INVT has launched the GD100-PV solar water pump drive, which can achieve both solar and AC power supply. The new generation of series has further upgraded to unmanned operation, automatic start and stop functions, and simplified debugging steps, bringing much convenience to farmers in its use. In addition, the automatic complementarity of grid power and solar energy greatly enhances the overall efficiency of the solar water pump system. At the same time, it supports remote monitoring, one-key start and stop of mobile phones, and system data detection and recording functions, which make the originally complex system visual and convenient. The overall system noise is extremely low, does not affect the lives of surrounding residents.
Value of the Solution:
Through the INVT solar pum solution,
1. In terms of maintenance: The solar water pump breaks the restriction of traditional oil energy and can be widely adapted in all kinds of regions without electricity. There is no need for various maintenance and upkeep costs. The overall system is more easy and convenient, with global unmanned automatic operation and efficient use of water, saving worry and effort.
2. Cost: The cost of solar power generation is about 0.1USD, much lower than the cost of diesel power generation of 0.5USD. Also, the maintenance cost of the solar system is very low in the later period. The energy-saving and economical solar pumping system has an improvement of more than 50% compared to diesel power supply.
3. In terms of service life: The system pump is frequency-controlled, and the system integrates dozens of pump protections, which can extend the overall system life by 50%.
Currently, INVT solar water pump clean and intelligent solutions have broken through 5000 applications in the Lebanese market alone. In addition, INVT has also helped more than 60 million households in more than 30 countries and regions in Africa, Middle East, Asia-Pacific, Europe, and the Americas to solve problems with water for production and life, with an annual power generation of over 10000 GWH. Each year saves more than 12000 Mt carbon emissions.
