INVT GD100-PV Solar Pump Solution for Center-pivot Irrigation in Saudi Arabia
Release time:2024-08-13
Click amount: 964
1. Project background
* Solar Pumping Overview
The solar water pump uses the long-lasting energy from the sun, works at sunrise, rests at sunset, does not require personnel supervision, does not require diesel, does not require power grid, can be applied with drip irrigation, sprinkler irrigation, infiltration irrigation and other irrigation facilities, saving water and energy, and can greatly reduce the input cost of using fossil energy power. It is a new energy and new technology application product for comprehensive system solutions to the global "food problem" and "energy problem".
* System Introduction
The solar water pumping system is mainly composed of solar water pumping inverters, AC water pumps, and solar panel arrays. It is widely used in desert treatment, domestic water use, agricultural irrigation, forestry watering, grassland animal husbandry, scenic fountains, water treatment projects, etc. INVT solar water pumping system saves the battery energy storage device and has no battery device. It directly drives the water pump to lift water, which has high reliability and reduces system investment costs.
2. Project Reqiurement
* The maximum AC pump power can reach 500kW.
* Connect to the central control system to achieve one-click start-stop monitoring of the system.
* The inverter needs to be given a dedicated signal output, and the central control system realizes control.
3. INVT Solution
* Solution Introduction
INVT GD100-PV solar pump drives cover 0.75-500kW power range. In this system, the GD100-PV realizes the smooth starting of large pump motor, smooth transition in the process of automatic starting of sunrise and sunset devices, and has dual RO outputs, which realizes diverse information collection for the central control system;
* Customer Value
- The Envision inverter does not require complex operation and maintenance, and all information keyboards are monitored with one click;
- After frequency conversion transformation, energy consumption can be saved by about 40% under the same production capacity;
- INVT global service network allows customers to choose with confidence;
4.  On-site Photos
