INVT VFD Boost Mexico's Water Industry Chain
Release time:2024-06-26
Click amount: 772
In 1977, the first shrimp farm in Mexico was established in the state of Sinaloa. After nearly 40 years of development, this coastal state has become one of the largest fresh shrimp farming areas in Mexico, accounting for about 60% of the national production.
Among them, the coastal region of Los Mochis, occupying a topographical advantage, local residents prefer fresh shrimp, and selling price is high, fresh shrimp industry chain is developing rapidly. There are approximately 900 shrimp farms in the region.
Fresh shrimp feed mill: seamless replacement for Delta, Danfoss VFD
Fresh shrimp aquaculture industry led to the development of feed mills, factories originally used Delta and Danfoss inverters, the current terminal gradually use INVT inverters, now the high power has been completely replaced by GD200A series Inverter.
Site Photos
Water Pumping Station: VFD Replaces Traditional Industrial Frequency for  Better User Experience
INVT GD200A series inverter solution with CE certification, excellent open-loop vector control algorithm for asynchronous motors, energy saving and high efficiency, replacing the original soft start solution.
* Stability: touch screen real-time monitoring of water flow, adjust the frequency converter.
* Energy efficient: Utilizing inverter to replace soft starter, energy saving more than 40%.
* Remote operation and maintenance: with IoT module, remote control as well as monitoring data.
* Long life: Thickened coating to resist salt spray environment, designed to last for more than 10 years.
Site Photos
INVT VFD have been helping Los Mochis water industry chain for 5 years with high efficiency and energy saving, which is highly praised by end users. There are several pumping stations under construction, and INVT will continue to support them and make more contributions to the sustainable development of the industry.
