INVT GD5000 Series MVD applied to DD Washer in Indonesia
Release time:2024-12-05
Click amount: 435
Abstract: This article mainly introduced INVT GD5000 medium voltage drive applied to DD washer and described detailed information involving the structure, principle, process, feature of DD washer. The practical application shows good speed control performance and stability of INVT GD5000 3.3kV drives and it is worth promoting.
Keyword:INVT, GD5000 MVD, DD washer, Energy saving
1. Brief introduction
Pulp and paper making process
In the pulp and paper making process, the washing, screening, purification, bleaching, post bleaching washing and concentration processes have the highest energy, chemical consuption, and water and drainage volume. It is recommended to use the counterurrent washing process in this section to promote water conservation and emission reduction.
DD washer process
The Drum Displacer washer(DD washer) has designed in response to the demand for improved washing efficiency, reduced operating, maintenance and capital costs. Today the DD washer is widely accepted by pulp mills all over the world. The family of DD washers comprises machines that can be fed at low(from 3%to 6%,LCDD) or medium(from 8%to 11%, MCDD)consistency. The number of washing stages varies from one to four. Due to its unique segregated counter-current washing principle, a high washing efficiency can be reached. The design and the construction of the DD washer has been further developed, so that even higher displacement washing efficiency can be achieved and this excellent washing efficiency has been proven in the trial. The DD washer installation positions include brownstock washing, post-oxygen washing and bleach plant.
2. Project information and solution
2.1 DD washer information
Motor tag at site
Motor power(kW)
Motor voltage
BSW Feed MC Pump
630
3.3kV
BS DD Washer
355
3.3kV
O2 MC Pump 1
800
3.3kV
O2 Feed MC Pump 2
800
3.3kV
Pump to Wenuri WP
500
3.3kV
Post O2 Feed MC Pump
315
3.3kV
630
3.3kV
Unbleached Tower Feed MC Pump1
710
3.3kV
BSW Feed MC Pump
18.5
380V
BS DD Washer
18.5
380V
O2 Feed MC Pump 2
630
3.3kV
Pump to Wenuri WP
355
3.3kV
Post O2 DD Washer
800
3.3kV
Post O2 MC Pump
750
3.3kV
O2 Feed MC Pump1
355
3.3kV
630
3.3kV
Post O2 DD Circulate Filtrate Pump
900
3.3kV
BS DD Circulation Filtrate Pump
800
3.3kV
18.5
380V
18.5
380V
Table 1.DD washer motor list
2.2 System solution.
According to customer demand and considering load condition and uniform spare parts, the below VFDs are selected for this project.
VFD Model
Power
Rated Voltage
Rated Current
Quantity
GD5000-A0800-3.3-S
630kW
3.3kV
140A
5
GD5000-A1250-3.3-S
1000kW
3.3kV
219A
10
GD5000-A1400-3.3-S
1120kW
3.3kV
245A
GD35 LVD panle
22kW
380V
45A
4
Table 2.VFDs for DD washer
Main system diagram:
Control sketch diagram
DD washer site photo
MVDs in the machine roon
MVD monitoring via Ethernet
3 Application and Advantage
After using VFD, there are some major advantages as follow:
* Energy saving, chemical saving: The pumps and washer are running at optimal situation and can save energy.
* Wide range speed adjusted: Because VFD is a step-less speed regulation, the pump and washer can be run smoothly with wide speed range. It means that the speed adjusted can be elaboration and sensitive.
* Increase grid line power factor: The grid line power factor is over 0.97. It can increase efficiency of the grid power.
* Perfect output waveform: Output waveform is perfect, less than 2% of distortion.
* Prolong motor working life time: VFD can keep motor running at optimal situation.
4.  Conclusion
Compared with old technology, the MVD driven method has many advantages. Especially significant energy saving. After commissioning, all the MVDs work very well, meet the process demand, customers are satisfied with INVT solution.
