Tension Control Demo System
Release time:2023-11-03
Click amount: 1118
Product: VS070-QS, TS600 series, DA200
Feature:
* Showing the basic structure of the winding equipment;
* Installing tension sensor to achieve closed-loop tension control;
* Realizing speed and torque tension control;
* Showing constant and taper tension control;
* The tension change is more stable by using the method of nonlinear taper calculation;
* It will be more accurate by calculating the volume diameter;
* Tension control is more stable by using integral separation PID control algorithm.
