INVT Products and Solutions Shines at CIIF 2024!
Release time:2024-09-25 Click amount: 372
On September 24, the 24th China International Industry Fair (CIIF 2024) kicks off at Shanghai China. Now the fair is still ongoing. We sincerely invite you to visit INVT at booth 6.1H-D008! Here we will show you the innovative products and technological charm at the exhibition!
Linear motor gantry dual-drive demo system
This demo adopts advanced gantry synchronous control technology to ensure high-speed response and ultimate synchronization accuracy, and is suitable for precision industrial fields such as laser cutting, AOI detection and LDI imaging. The demo features high-precision synchronization, out-of-tolerance early warning protection, real-time fault shutdown safety mechanism and convenient zero-back mode, which makes the operation of gantry equipment more intelligent and more secure!
Winding and unwinding demo system
The winding and unwinding platform is used for various industries such as printing, packaging, and lithium batteries. INVT winding and unwinding demo system integrates features like flying shear, tracking shear, special-shaped winding and unwinding, automatic correction, and IoT capabilities. It offers excellent control performance, supports up to 32-axis control, automatically calculates roll diameter, maintains tension fluctuations within 3%, and has a short tuning time, making it ideal for applications with rapid speed changes.
Hot Redundant Frequency Converter Demo Box
INVT GD350-HR series hot redundant frequency converters provide redundant operation for a single motor using multiple frequency converters, ensuring automatic balancing of output current. If one frequency converter fails, the others continue to operate normally, ensuring production safety. Once the faulty frequency converter is repaired, it can be smoothly and automatically reintegrated into the system, thus maximizing production reliability and safety. This technology is widely used in industries such as chemical and steel where high reliability and safety are critical.
EOE Function Box
Also known as "One Network to the End" remote debugging, EOE (Ethernet over EtherCAT) allows for streamlined motor drive configuration and debugging. Traditional motor drive software requires separate connections through serial or other ports. With EOE support, the motor drive's EtherCAT network handles both control communication and configuration/diagnostics, eliminating the need for additional wiring. The debugging software sends configuration or debugging commands via TCP/IP through the EtherCAT master station to the motor drive.
Elevator Demo System
INVT GD350-19 Crane Special Inverter, designed specifically for elevators, is widely used in driving scenarios for lifting, pitching, luffing, hoisting, trolley, rotation, and grab mechanisms of lifting equipment. With its outstanding control performance, it achieves zero-speed hovering; reliable braking sequence ensures smooth start and stop; feedback-free anti-sway technology significantly enhances operational safety and efficiency; and its expandable communication platform seamlessly integrates with mainstream buses, helping elevators stand out in various complex environments!
Synchronous Reluctance Motor Demo System
In recent years, permanent magnet synchronous motors and synchronous reluctance motors have been widely applied in various fields. The Inovance GD330 series synchronous motor special inverter is specifically developed for permanent magnet synchronous motors and synchronous reluctance motors. It utilizes our latest Euler software platform, greatly improving motor parameter adaptability and control.
There are only 2 days left until the end of the exhibition. We look forward to seeing you at booth 6.1-D008!
