INVT GD300-01A VFD for Permanent Magnet Variable Frequency Screw Vacuum Pump
Release time:2024-06-14
Click amount: 740
With the continuous widespread popularization of vacuum technology applications, various vacuum-related equipment have developed very rapidly. At present, there are many types and specifications of vacuum pumps. However, in order to meet the different process needs of various industries, the improvement of old products and the development of new products are still the fundamental way for enterprises to continue to grow and develop, and they are also an important means to improve economic benefits.
The permanent magnet frequency conversion screw vacuum pump is a highly reliable and energy-efficient vacuum pump that uses permanent magnet frequency conversion technology and screw technology to achieve vacuuming effects through screw extraction and exhaust. INVT provides a vacuum pump system solution for a vacuum pump manufacturer in Shenzhen China, which comprehensively improves the user experience and makes the equipment more energy-saving and efficient.
INVT electronic control system solution
For the current vacuum application field, electronic control system solutions have become one of the key factors to ensure the success of the project. INVT relies on years of industry accumulation to provide customers with HMI+GD300-01A series air compressor inverter systems solution. The permanent magnet frequency conversion screw vacuum pump is driven by GD300-01A, so that the speed of the machine can be adjusted according to actual needs to achieve more energy-saving and stable performance.
 Solution advantages
* High integration:
The GD300-01A series air compressor dedicated inverter integrates a dedicated vacuum pump control function, eliminating the need for an external PLC controller.
The size of the frequency converter is reduced by more than 30%, which improves the integration of the electronic control system and saves installation space.
* High stability:
The perfect vacuum pump control logic and comprehensive process protection functions improve the system vacuum control accuracy and stability.
Control the start and stop of the fan through the oil temperature to ensure stable oil temperature.
* Energy saving and efficient:
Permanent magnet frequency conversion intelligent operation saves more than 40% energy than traditional vacuum pumps, with faster pumping speed, higher efficiency and energy saving.
It has functions such as intelligent sleep and wake-up, scheduled power on and off, etc. to help reduce equipment loss.
It has a wide pumping speed range, constant vacuum degree, high stability, low vibration and noise, and is more environmentally friendly.
Summarize
The successful application of INVT inverter on vacuum pumps not only provides cost-effective system solutions, but also provides more convenient one-stop services, making the installation and maintenance of screw vacuum pumps easy and fast.
At present, INVT provides energy-saving, efficient and stable system solutions for various industries, focusing on market user needs and technological innovation, helping enterprises to reduce costs and increase efficiency.
