INVT Solution for Screen Printing Machine in India
Release time:2024-07-25
Click amount: 565
Abstract:  Oval type automatic Screen printing machine is based on rotary screen printing machines, its performance and printing process is very well. The machine adopts modular design, high-strength aluminum alloy structure, the main rotation system adopt high-precision servo drive to assure the fast and stable operation, with the features of accurate printing, reliable performance, easy operation. Suitable for water-based ink, plastisol ink, Solvent ink and other printing processes, standardly configurated with flocking function. It's best for pieces and various garment printing, and also flocking processing.
Keywords: AX PLC, Ether CAT, Remote IOs, VS HMI, DA200, AE1420
1. Introduction
Machine Procedure:
* Control system:
1. HMI interface and PLC system ,self-diagnosis and printing station control
2. Real-time display of production speed to more clearly control the operating costs.
3. Different operation modes: Flood and squeegee mode with lift, Flood and squeegee mode without lift ,Print flash Print mode,automatic cycle, single cycle.
4. Each station can be controlled individually and be operated work or stop easily, also can control the entire equipment ON/OFF.
5. The speed and pressure of squeegee is independently adjustable.
6. Flood bar and squeegee can be fixed and took off without any tools and speed can be control by change the frequency of VFD.
7. The stop position of print head can be set freely with adjust of sensor.
8. AC drive system, stepless speed regulation.
9. Screw adjust position, accuracy±0.05mm
10. Printing times and route can be set free in HMI as per requirements
* Rotating System:
1. Servo motor drive, running precise, high-speed, stable running of panel in rotary movement
2. Forward and reverse of machine as per print loading and unloading and reverse the station number logic is also possible in this machine.
* Module Expansion:
1. Customers buy the printing machine with the suitable numbers of stations according to demand. For further needs,you can quickly and easily enlarge the machine in every two-station units.
2.1 Project information
Site information: Garments company
2.2 INVT solution
Product
Model no.
Qty
Application
PLC
AX72C-1608N
CONTROLLER
HMI
VS102HCS
CONTROLLER
REMOTE IOs
AE1420
7
MODULE
SERVO MOTOR
SV-DA200-2R0E-2-1A0-1000
PALLET INDEXER
SERVO DRIVE
SV-DA200-2R0-2-N0
PALLET INDEXER
2.3 System Configuration:
 2.4 System commissioning
 Control panels
3. Advantages and benefits
1. Highly versatile. Each printing head is completely independent and can
    be individually programmed.
2. Easy programming and program store with the digital touch screen.
3. Pallet automatic levelling system: pallets are automatically identically
4. levelled in height and in horizontal achieving a perfect printing accuracy
+- 0.5mm.
5. The working pressure of each squeegee can be adjusted independently.
Self-aligning and tilt-adjustable squeegees.
6. Digital control of squeegee speed: from 0.15 to 1.5 m/sec.
7. Double centring device located on each head for greater fitting precision.
8. Extremely accurate micrometric system that facilitates design changes
and fitting.
9. Innovative system of pallets free, easy to change in seconds without
tools.
10. Operators accessibility. Prevents operator fatigue and improve the
productivity. Machine speed is 746 t-shirts per minute of 55 pallet machine
11. Intermediate areas for pre-drying.
4. Conclusion
This T-shirt/screen printing machine is installed in garment industry and performance, accuracy and stability all meet the process requirement. We have given INVT solution against Omron and Mitsubishi controller.
